1 - 13 of 13 Posts
Brand Newbie so please bear with me. I have a 97 S320 LWB and Im trying to debug the few problems it has. If anyone could give me a little direction I would be appreciative.
1)Tilt wheel is stuck. Major problem or is there something I can try before I see my mechanic? How involved is the issue?
2) I think my car has SLS (its a LWB), but I dont think it is working, Is there a reservoir somewhere I can check fluid level or does my car not have SLS? Related, I read there may be a EDS (Electronic Dampening System?). How do I know if my car has either?
3) I think the car needs shocks. Is this a reasonable assumption for a 22 yr old S320? Im guessing I should get the SLS or EDS fixed first IF I have it.
I have a few other questions but I will hope for some guidance on these first. Thank you in advance for any help you may give.
Kal El
Steering wheel tilt and extend/retract is controlled by a box under the passenger side floorboard. It also controls the mirrors. Steering wheel issues are usually that box, but it can also be the switch. When you activate the switch, you should hear clicking coming from under the floorboard. If you hear clicking, it is the box. If you don't, it could be either. You should also hear clicking when you activate the mirror switch.
You could have either SLS or ADS. SLS is far more common. There is a reservoir under the left side plastic cover. You can determine what your car had from the factory by decoding the serial number on one of the websites in the stickies. If you have either SLS or ADS, a common problem is the rear accumulators going bad, needing to be changed. A search here will give you lots of info on changing them. When they go bad, the rear suspension essentially becomes solid, giving a bouncy ride. Mercedessource on YouTube has a series of videos on the SLS system. Well worth watching.
You are very kind to help. You said the reservoir is under the driver side plastic cover. Where is that cover on the driver side...in rear, under hood or trunk, or did you mean under/behind the body-side skirting?
Also, someone told me there was a problem with what they called "junk wiring" in the S-Class in the mid 90s. Would this apply to my 97 S320 ?
Thanks so much for your help. I owe you one.
The reservoir is driver's side, engine compartment, under the small cover at the front of the of the larger plastic engine bay cover.
Moderator
Good day, and welcome to the forum.
97 S320 is not known to have engine wiring problems, but... your steering colum is tied to the outside mirror fuse, and I can tell you maybe upto 99, but my 98 had mirror wiring problems; The fuse would blow on adjusting the mirrors, so you may have this. This may be a reason for the colum is not working for you too...
No SLS on these 320s just plain shocks. To service the low-side of the AC is a tank of hydraulic fluid under the right drivers side black plastic cover. if you had SLS.
As newbie, have you changed your rear heater tee as you blow that tee on the road, and you have under a minute to stop that engine. Change the tee with a actual Mercedes brand tee, or Rein Tee(Rein makes the MB tee) - No used or ebay/craiglist/offerup/etc...
The tee's are good for safely upto 70k-80k miles after that you are in the danger zone for failure... Here is the tee:
Read all about it...
https://www.benzworld.org/forums/w140-s-class/1320788-evil-lurks-under-hood-really-devil.html
Change this one too:
https://www.benzworld.org/forums/w140-s-class/1719760-another-coolant-fitting-breaks.html
https://www.autohausaz.com/pn/1408301696
Then read my posts here... I'm looking for that California to New York reliability every day, and that what it takes....
All the best,
Martin
And let me add to MAVA's post. Yes, change the "Tee" but also the small hoses attached to it. In my '97 the Tee was indestructible but the hoses were all puffed and ready to let loose. As MAVA says, you have only a minute or two to shut the engine down after loosing the coolant. In fact pay attention to anything MAVA says. He is a "fountain" of knowledge along with 3-4 other members here.
Anziani
Moderator
Customary photos of your car are a must.
If your tilt steering, mirrors and seats arent functioning, its controlled by a module in the trunk.
Uh, no. Mirrors and steering wheel are controlled by a module under the passenger floorboard. Seats are controlled by a module attached to the bottom of each seat.
Moderator
Ive replaced both my MY94 600 and MY97 500. Both cases it was the module in the trunk. Are the trunk and floorboard modules supposed to work in tandem?
I only speak from experience so if you are armed with actual diagrams please educate me
System description, fault finding, component layout for the mirrors and steering column is here. The module involved is N32/9, under the passenger floorboard:
STAR TekInfo Mirrors/column
Same here for the seats. Modules N32/1 and N32/2 under the seats:
STAR TekInfo Seats
The module (N57) in the trunk controls the windows, sunroof, and portions of the central locking, and is described here:
STAR TekInfo Comfort module
Wiring diagrams for the W140 are here. Directions on how to use them have been posted several times so I won't repeat them here:
StarFinder
Discussion Starter #11
I want to say Thanks to all of you for your help. You are a wealth of knowledge. Im trying to take care of the functional parts first and then the comfort features.
Im not really sure how I could help any of you but if I can, please drop me an email.
Discussion Starter #12
Based on what youre saying, I got bad info. I was told on the LWB/long wheel base S320 I hav that I have SLS. Now I know its my shocks.
And Thanks, again for the info on my heater T. I had no idea about that but I promise it will be the next thing I look at.
Discussion Starter #13
I live stateside in Virginia. Any idea where I can get Module N32/9? My usual sources dont have a clue.
1 - 13 of 13 Posts
About this Discussion
5 Participants
Kal El
Mercedes-Benz Forum
Full Forum Listing
