I have recently purchased a 1989 MB 560SEL with 290k miles and the odo has stopped working but the speedo still works. It runs remarkably well for it's age and mileage. I do not have a history on the car. I am driving the car almost daily and it still has good power and the transmission changes flawlessly. I have replaced the gas pedal and gotten an oil change. The only issue I have is that it idles a little rough. Almost as if it is misfiring but I think it's a fuel issue. I have ordered a fuel filter. I don't know but I would assume that the engine is choked when it is cold and it doesn't start idling rough until it's warmed up. So I am replacing the fuel filter as a first step to curing this issue. I don't the date of the last tune up but there was a used set of wires in the trunk which tells me it was either recently done or maybe someone already tried replacing the wires to cure the misfire. Any suggestions?
Outstanding Contributor Always Remembered RI
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
