I tried to start the ML this morning. It wound over but wouldn't start. I've had no problems lately and its been running well. I tried the spare key but with the same result. When I checked the fuel pressure at the rail, there was no pressure at all. I swapped the pump relay and fuse (and...
Folks, need some help. 1998 ML 320. Both bulbs are out and the screws are stripped and rusted, broken off (that hold the lenses in place), I was able to remove the lenses and access the bulbs. I need to remove that plastic trim housing that houses the lights. I barely removed one phillps...
Had our radiator replaced as it was leaking, found out that it is combined with the power steering. Just found out that it is leaking again. And my power steering is still not working. I am unable to drive this car. It has just over 200k on it.
Is there any known issues I should know about it...
So, I replaced my intake manifold on Sunday and when disconnecting the Engine Coolant Temperature Sensor, it broke at the connector, the pins were still intact so I went ahead with the replacement and just tried to slide the connector back over the pins to start it (I have purchased a new sensor...
