New to me 2001 ML 320
1077 43
I have always wanted one and finally found a single owner with some miles but great shape. I leaks anywhere. Originally an Arizona car.
couple of questions that I have?
nav- states not installed. The only slot I have behind screen is cassette. I do have a multi cd cartridge in rear. Can I get nav for this ML with what I have? Or just swap stereo for newer? Also Bose system.
Also missing a piece from rear bumper. Can anyone tell me what it is? See pics.
Also owner couldn’t find cars handbook. eBay?
thanks for the reply’s
Reactions: ed7c9 and khomer2
1 - 20 of 44 Posts
2003 ml500, 2004 ml350 2005 ml350 SE 2022 F150 XLT
Looks good, nice to see a non silver, black or white
Nav do not bother, the maps are so out of date you will get warnings you are on unimproved roads! Best to change out the head unit and use preferred phone app. The nav in our 04 works it is fun every now and then for laughs.
As to the plate it is center bumper cover sometimes called hitch cover plate. Though it needs to be notched for the hitch. There is a prenotched hitch version but rare I have never seen one on an ml with a MB hitch even dealer installation they cut the plate. In fact M B published a service bulletin on how to cut it with dimensions.
They are ordered by color, last I looked some colors were still availablenot sure on the gold. Will be very hard to find you color at a pick apart.
i think I have a blue one in the shed.PM me if interested
· W163 and General M Gremlin
+2 on changing the oem HU.
You probably have FO (fiber optic) Bose. You'll need to by-pass the proprietary FO amp system, etc OR do the loop-da-loop on the FO cable when swapping.
ML55amg wheels? maybe?
Find yourself some ML55 amg 18" wheels and keep those for winter shoes.
Please Complete your Profile by adding the year and model of your car, so it will show next to every future post under your avatar.
Bose amp has to be gutted (literally) - that's what I did in my situation and re-purposed the shell and it's oem connectors.
Goto the w163 sticky's - lots of great info in there
post # 18
Reactions: tpdtopcop
meh, color match the code or sample, with a suicide can (you can buy custom matches, I do, when needed - doesn't cost that much more) or add a trailer hitch back there with a step bar.
I hate drivers who can't parallel park. If they want to damage there bumpers.... :)
2001 R129 SL500, 2002 W163 ML500
I got really lucky - DeadBenzAnimator had the factory hitch cover with cutout for factory hitch, and in my color! It had lots of overspray on it of different colors, but lacquer thinner cleaned it up perfectly. BTW, does the job on touch-up paint... and yes, it's a factory cut out, not trimmed in any way. Picture from 2021 eBay receipt...
Automotive exterior Gas Rectangle Tints and shades Auto part
2001 ML 320
Discussion Starter · #15 ·
can you steer me to a hitch that will fit?
Lots written on hitches, there are 4 parts get a hitch from a pick and pull yard. Best to get an MB hitch Bring a very good breaker bar the bolts are usually lock tired and torque high!
1x Hitch and 4 bolts
2x corner brackets and 8 bolts and sleeves
1x MB wire harness left access panel to hitch (you can splice it in but the plug and play MB is painless) don’t forget the fuse?
Yes there are other brands but they usually do not have corner brackets which increases towing to max 5000lbs
2001 ML 320
Discussion Starter · #17 ·
Does an OEM Mercedes trailer hitch look like any other type?
Tire Wheel Car Vehicle Automotive tire
Many of the after market hitches tend to have a gusset plate welded from the receiver to the mounting plate. Every part on a MB hitch is labeled with a part number it will start W163 xxx….
Notice the notch in the bumper! The bumper will not attach with out it
2001 ML 320
Discussion Starter · #19 ·
Thanks. I believe I have seen several in ebay for sale
1 - 20 of 44 Posts
