1 - 10 of 10 Posts
S320W
hey guys,
iam thinking of buying new amg wheels and new set of tires for my S320. This is what iam thinking of doing:
Will be putting 18.8.5 Aero II with 235/50YR18 yokohamas in the front
and
19.8.5 Aero II with 255/40YR19 yokohamas in the rear.
Has anyone ever done such configuration? was there a problem in doing so?
BenzWorld Tire & Wheel God
It will make tha car drive extremely bad ... and change the overall dynamics and handling ...
It will make tha car drive extremely bad ... and change the overall dynamics and handling characteristics
S320W
Thanks for ure reply Luke. I recently found out about these problems associated with such ...
Thanks for ure reply Luke. I recently found out about these problems associated with such configuration.
Widebody SEC
expand on the answer please
luke, could you explain why it would be "extremely bad".
235/50-18 = 27.3" diameter
255/40-19 = 27.0" diameter
the front tire side wall height ...
the front tire side wall height would be 4.65"
the rear tire side wall would be 4.00"
so as you can see the rear tire has a shorter shorter sidewall this will have alot less deflection and thus induce a tremdous amount of underteer ...
E430T + 300SL (W107)
I guess the NSX was (like a lot of mid-engine cars who tend to be oversteered) has a chass...
I guess the NSX was (like a lot of mid-engine cars who tend to over-steer) has a chassi that from the begining designed for this kind of tire set-up.
Luke could it work with a bit of suspension and chasi work to the car? Or if you had ti...
Luke could it work with a bit of suspension and chasi work to the car? Or if you had tires that had the same aspect ratio? So if the front wheel tire combo is smaller than the rear wheel tire combo could it work? I know people have done this type of stuff to muscle cars for ages.
Re: Luke could it work with a bit of suspension and chasi work to the car? Or if you had ti
And if you try it on a Benz it might handle like one... [;)]
1 - 10 of 10 Posts
