1 - 12 of 12 Posts
1992 300SD, 1986 300SDL, 1995 E420
On 92 models I believe the central locking pump is responsible for the trunk handle not the pse pump in the trunk. It is also responsible for a\c flap in the middle and reverse guides.
CLS350 C219 2006
Hi,
I think the info is incorrect. I got a '92 500SEL.
PSE (Under the right rear seat) does Trunk handle, lumbar, AC, central locking, reverse antenna, ...
Closing Assist Pump (in boot, behing passenger seat on left, beside tank) does that: closing assist, nithing else.
Cheers
2005 E55 Designo
Hi,
Cheers
exactly nubyOz. no burnt fuses.:confused:
door assist works as it should, but I heard a burbling under the boot latch near ext lock the day before the pse quit, i guessing vaccum hoses as a possible suspect.
CLS350 C219 2006
Mine is a acting a bit strange, need to close boot always twice, first time it comes up again too much.
Will take my latch apart next few days and post pics.
Cheers
SL55, 300SE, GL450, Daytona 955i
Cheers
in 92-93 models, the PSE pump (under rear seat) does EVERYTHING, but door closeure (for trunk and 4 doors)
W140 Mercedes 500 SE, 1992, European, 440.000 km
central locking pump (only one function of more) IS called PSE pump. it is under the rear seats. The another pump (close assist pump) is in the trunk. I can be 100% sure because my car has not any close assist pump at all ... and the trunk handle is working.
2005 E55 Designo
Discussion Starter · #9 ·
I ran a series of tests all the power points to the pse but nothing works.
I swapped the new pump motor (bosch)into the old hella pse unit & it ran, but didnt make anything work. (I did try the motor's wires in both directions)
Then replaced the pump motor back into the new bosch unit & it bolstered my seat for a fraction of a second & shut off not to work again.
Again no burnt fuses no smell, nothing.
I checked the motor & pump again to see if it failed & its ok, & works fine.
I'm almost convinced the circuit board and/or electronics failed on the new unit after less than one year of service...what a rip.
I'm going to ask autohaus AZ (bought from) if they can give me another one at a reduced price.
The only thing i didnt do is put the pse into another w140 to see if its my vaccum lines as suspect.
I am not sure if I missed something, but did you buy a new pump and take it apart?
WHY??
2005 E55 Designo
Discussion Starter · #11 ·
WHY??
The brand-new pse was in my car & failed after only one year. That includes being in climate-controlled storage for six months.
I would like something that works at least a couple of years minimum for 309$ plus shipping:rolleyes:
if you bought the pump from AZ autohaus, you should have some sort of warranty on it.
1 - 12 of 12 Posts
