1989 560 EUROSEL 1984 190e8V 2000 e320 sport
anyways i have been working pretty hard on redoing a project car 190e 1984
so my interior cluster lights havent been working since i picked up this car...
so in my haste i decided it may be a instrument cluster thing... so noe i ordered a used intrument cluster pluggede it in and still no cluster lights and also i also see that there is no front dome light i checked fuses etc.. and changed the bulbs in both units still no lights.. i heard there may be a fuse behind the cluster if so where... also in my haste if anyone has the dome light pics im getting a reading to the actual switch but cannot get anything but rear dome light on thanx shane
"fuse" behind your cluster, NOT for your year. If no lights on cluster, dash switches, climatic control, blower switch & power window switches...than 99% I think the dimmer circuit got shorted out at one time. Because there is NO fuse on your cluster...so a skinny trace on the circuit board inside your cluster "BURNED".
Front dome issue, check bulb, make sure switch on dome light is NOT set to "OFF", check switches on both front doors.
edit: here is that burned trace I was talking about....
so did you have to get a new board
