Hello all, I am a new member. I do not have a mercedes benz yet but i am in the market for one. I do not have a whole lot of cash and found a 1983 300sd diesel benz for sale, it has 300 thousand miles. I am not scared of the milage because i know diesels last pretty much forever. for 900 dollars i think its a good buy but im looking for advice and input. Is there anything i should keep my eye on when looking at it, anything i should check, anything to listen for when test driving it, anything i should know at all? Thank you for help in advance hope to be a mercedes diesel owner in near future.
I had an 81' 300CD for years, sold it unfortunately with 440k and she was still strong. I never had a problem with mine, just kept the maintenance regular and she was wonderful. Obviously since I had no real issues, I am not helpful as to what would be important to evaluate and I am sure someone else with chime in with the correct procedures. Good luck.
1989 300SE (Rear Ended & Junked) 1995 E420, Fully Loaded with Ortho Seats & Rear Sun Shade :)
Weird how both registered on the same date, i.e. 12/03/2010, etc, etc.
How about also including your locations and doing a forum search as well as reading the sticky? Will help a lot.
I am from Central New Jersey, the car i found is in Pennsylvania. the ad says the car smokes a little at start up but then clears out and goes away? Some quick advice and input to help me would be great since i dont have much time to do a whole lot of searching and research
Most, if not all smoke at start up, mine do.
When driving, make mental notes of odd sounds.
These cars are seemingly slow, do you get a bunch more acceleration once the turbo spools up? ~2500 rpm.
How does it shift, does the climate control work?
Im not too worried about the climate control, im more of a windows down guy..im more concerned with the motor and trans. what would cause it to smoke? im new to these cars, i previously had a diesel truck but that was brand new...im looking for some basic info on these cars, any problems i might run into, etc.
If maintained, these engines last a very long time. It has an automatic altitude adjustment device, ALDA, which is told what to do by a pressure line coming from the intake manifold, going to a switchover device on the half fire wall, then to a round silver box. If this line is clogged, the ALDA won't get the signal to add much fuel before the turbo spins up, creating an extremely slow take off from a dead stop.
That has been misdiagnosed more than once.
The transmission on mine does flare (a hesitation between gears) occasionally, but is otherwise fine.
If you can have a knowledgeable person to check it out, that will certainly help.
