1995 sl500
Hello
I have a 1995 sl500, I bought it with the newer xenon projector headlights on it.
They work fine, when I change to high beam the low beam turns off as it should be with the original headlights, but with xenon the low beam should stay on even with the high beam on.
How can I achieve this? Is there a relay that does the turning off the low beam?
Thank you
Greek God of the R129
SL500-500SEL-190E
I have given the info many times look in the posts.
There is a connector over the brake pedal you have to bridge two wires
I think the 1 and 3 or 3and 5 I don't remember.
Look for it.
Regards.
aam.
1995 sl500
IT WORKED PERFECTLY
Thank you aam
I found your post and bridged 1 and 3 and now it works as it should.
Again thank you
