Ok Changing the fuel lines from the tank tomorrow. Is there some type of filter in the tank that I should take out to clean. And what type of sealent should I put on the threads or do I need it at all?:)
There are three lines, a supply to the engine, this has a strainer with an "O" ring, no other sealing is required.
Also a fuel return line, this has a seal ring, copper, I'm assuming, you'll need another, part # N007603 014106.
The third is a vent, no seal or "O" ring.
