1 - 10 of 10 Posts
ML320,C230,S320,A190
I have friend who had installed a set of AMG C32 Front brake system(Rotors, Capilers) on a C320 without any modication. He also told me that it is interchangable amount all C class 4 doors Sedan only,since the Coupe seems to have a slightly different setting on their brake system than the 4 doors.The rear set may be interchangable too.
For those who are into upgrading their brake systems, might look into it, as it cost much less than any aftermarket one, also at least it is still Oem MBZ product!
The Coupe may have to wait till the C32 Coupe is out, before I can check.
Member
'00 ML320 Elegance
Thanks Paul!...
That's good to know. Changing the rears will only have a marginal effect though, since most of the braking is done by the front brakes.
2002 C230k
I think your friend is mistaken. Evosport is offering C32 AMG brake kits for all the ot...
I think your friend is mistaken. Evosport is offering C32 AMG brake kits for all the other C's including the Coupe. They say it is a direct bolt on swap. You will need C32 wheels or something similar, since the thick caliper won't clear the standard wheels.
02 C230K
Can the C230K fit with the C32AMG rotors? I really like the look of the drilled rotors.[...
Can the C230K fit with the C32AMG rotors? I really like the look of the drilled rotors.[:)]
2002 C230k
You will need to use the C32 wheels with the C32 brakes.
02 C230K
Anyone make drilled rotors for C230K? I know Brembo does make it for the W203 seden....
2002 C230k
Same rotors are used on both sedans and coupes.
Discussion Starter · #8 ·
C32 brake system
You are right,Lynn! Sorry to have forgot to mention the change of 17" or bigger wheels, since my friend's C320 has the Evolution package with 17" wheels, and my C230 Coupe has the AMG wheel package, so I miss the point.Thanks!
02 C230K
The Evolution package in the C230 Coupe doesn't come with the 17" AMG wheels in North Am...
The Evolution package in the C230 Coupe doesn't come with the 17" AMG wheels in North American, the one you mentioned is the Evolution II package, comes with 17" AMG wheels and body kit.
Discussion Starter · #10 ·
As in Hong Kong
we have the option of AMG package with 225/45/17 in front and 245/40/17 in back with sport suspansion,and a light body work.
1 - 10 of 10 Posts
