I picked up a 1995 model E300 for what I think was a good deal the other day. I'm going to try and fix it up best I can. I have never owned a Mercedes before. I was wondering what I should address on this car if anything? Also had a few issues I could use some advice on: (I'm going to order a Bentley manual, I just need to resolve these issues asap).
Does the car have an electric fuel pump to supplement the IP or does the IP act as the fuel pump?
The temperature gauge will start out normal but then jump all the way to 120C as if it is getting a poor signal. Where is the temp sensor located so that I can make sure it has a clean connection? Or will this require that I replace the gauge?
It leaks a lot of diesel which makes it hard to start if it has been sitting. From what it looks like I will have to remove the intake manifold to get to the fuel tubes. Are there O-rings or something in there? VW fuel pipes don't have O-rings but I'm assuming this car does or it wouldn't leak so much. Any idea where I can find these parts?
The factory radio requires an anti-theft key to be entered and I do not have the owner's manual. Can the dealer supply this key if I give them the VIN?
The tachometer doesn't work. How do I verify it is hooked up correctly?
The vinyl in the interior is coming apart in several areas. Is there any type of glue that is recommended to put it back together?
Also, If anyone has a website that sells little odds and ends parts for a good price it would be appreciated. Thanks all.
