1 - 20 of 23 Posts
1991 SL 500, 1977 Ferrari 308GTB, 1980 Corvette, 1990 Ferrari Testarossa, 1999 Ford F150
I had ordered some new Crystal clear corner light for my car and after reading all the comments here I was kind of nervous about what I was going to receive. I got them today and installed them. Well, guys I'm very happy with them. Comparing them side to side with the Bosch they are exact replica. They fit just as nice, tight and solid. I removed them twice to make sure they held in place correctly and they are. No complain at all. Nothing cracked or broke when installing/removing.
I got them from CASAKEYTW on eBay.
Mercedes Benz Crystal Corner Light 129 R129 SL320 SL500 Corner Lights Lamps | eBay
1998 R129
1998 R129
Looking at the pics closely right next to the clear corners I bought, theyre the same units. Im surprised you like them, I couldnt leave them on for an hour. Glad youre happy with them though. Mine are going back for a refund
1998 R129
Sir, might I ask which headlight units you have? Those clear one pieces are exactly what Im looking for and look a heck of a lot better with those clear corners too!
Discussion Starter · #6 ·
i don't know!
I can't tell you exactly what they are because they were on the car when I bought it. The PO told me they were euro headlamps. I know they are glass lenses without the plastic trim around them. I'm sure someone here will tell you whay they are.
1998 R129
i want those so bad. A gentleman on this forum pointed me to a set of the drivers side like those, ut I cant find a matching set for both sides. Theyre also not cheap. Theyre gorgeous!
· R129 HTT Founder Member
040 96' SL500, 368 08' E550 4Matic, 9147 13' Sprinter 2500
@Muti007 those are the euro headlights. Contact the seller to see if he has both sides available. For some reason he only seems to post on side but can get both if you request it. Just make sure you contact him first to check availability .
Sent from AutoGuide.com Free App
1998 R129
And now I have to go back outside to take apart the entire passenger side headlight unit to try and get that damned fused lightbulb out of it! :(
500SL
could you guys suggest a place to get a Euro right side front flasher?
I have a ex-Japan R129 and I'm having a very hard time finding the correct part on this side of the ocean.
The Bosch number on the current 1 is 1 315 106 915. I haven't been able to find an MB exchange yet...
@yatzee I'm guessing you mean the lens located on the fender correct? Since it was never on the U.S. cars you may have to source it from overseas. Try German eBay.
1998 R129
500SL
Just heard back from the local dealer - over $100 for the lens - 7-10 days for them to get it. Not great, but the car needs to pass a safety so I'm short on choice
Yeah pretty certain. If you look it has 4 pin connectors instead of the 3 found on US models. Also it doesn't have the funky zig zag looking thing in the corner.
1998 R129
Thanks brother. So even though the pin config is different, it should work on my 98? If I have to buy what Im looking for piecemeal Ill do that.
1 - 20 of 23 Posts
