Hey all,
New CL55 owner here with a couple of questions:
1) The licence plate light on the boot (trunk) lid on the right hand side doesn’t work, tried a new bulb but there’s no power going to it.
2) The keyless go card had a ‘check card battery’ on the display, changed the battery, cleaned the contacts but am still getting the message.
Any advice would be gratefully received.
Thanks!
Discussion Starter #2
Solved the first problem, the two pin connector that feeds the power to the build holder was dirty, cleaned with switch cleaner and all works perfectly.
Still got the keyless go problem though
did you unscrew the bulb holder from the outside & lower it out, or did you have to go thru the inside of the trunk & remove the lid liner?
Low battery voltage in your key can cause issues. If you have not changed the small battery in your key-it's time. Only get 4 years out of the remote key battery.
