i want new c class headlights there fogged up it would look really good right new headlights its an 04 c320 can someone help me out where to go about this and a price range?
-thanks
You can get plug-and-play "Depo" brand bi-xenon headlights on eBay for about $370 for the pair.
2002 C320 wagon 1987 560sel 1997 E320
Rodney's got it straight... the depo ones on ebay are the way to go. Put a set on my '02 c320 wagon, black... looks killer. Makes the car much better, a very worthy investment.
2003 C320 Sport Coupe - 2002 CLK320 Cabriolet - 2012 E350 Cabriolet
Another option is DIY headlight restoration. There's a kit you can buy that has a mini electric sander which you can use to sand out oxidization.
There are also kits with a shampoo type thing where you just rub it on the headlights, but that doesn't do all that much.
2005 C230 Sport
Find a shop that uses the BG headlight restoration kit. It is a 5 step process. Wet sand with a small air or electric sander. There are 2 different grit pads pink then blue. Polish with air or electric polisher, 2 different polishes/ polisher pads. Then A UV protectant/ sealer is put on. Most lights come out looking brand new. If the sealer is put on once a year the service has a lifetime warranty. Most shops charge between $150 -$200.
