1 - 8 of 8 Posts
2005 Mercedes Benz C230 Kompressor
I just bought a 2005 Benz C230 Kompressor,and actually while looking for a solution to a nagging problem with the ride,i discovered this forum.I'm sure i will get solutions here.Dealing with two problems
1)The is a message on my dashboard saying Battery Alternator visit workshop,i bought a new one and the message is still there,the electricians says the alternator is giving out 12.5 volts while the car is on idle and 11.7v when loaded and so he concludes that the alternator i bought is bad,can someone throw more light on this.
2)I noticed while driving if i leave the steering my Benz moves to the right,even after allignment this continued,i was told that this could be caused by some bad bushings on the right tire side,can anyone advice what i should do.
Thanks for all the help i hope to get here.
· Outstanding Contributor - Always Remembered, RIP
Zotye Auto 1.5T T600 2016
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
1. Your alternator is bad.
2. Try swapping the front wheels left to right and see if this cures it or actually makes it pull the other way, this may be a bad tyre.
Regards
Thank you very much. Also i posted my VIN on your thread for a read out,is it true that engine number can't be easily seen in the 2005 C230 Engine compartment when the hood is opened?
I am away on business at the moment, will answer you vin decode and other questions either Monday or Tuesday when I am back in the workshop. In the mean time please complete your profile with car and year and whilst not terribly important your location.
· Outstanding Contributor Always Remembered RIP
216 with everything. 2002 SL500 with everything. 2009 SL500 with everything.
I have done it for you
Its very hard to read any MB engine number from above, you just cannot see it easily at all
1 - 8 of 8 Posts
