21 - 24 of 24 Posts
1998 SLK230; 2008 E350
Discussion Starter #21
Changed the motor mounts and that wasn't it. Now back to replacing the axle. Will order an A1 Cardone and see what happens. What a nightmare!
Discussion Starter #23
OK. The nightmare is finally over. After weeks of agony (and many trips to the shop), it was indeed the GKN Axle causing the shakes. I replaced it with a Cardone Reman and the vibration went away. I will do a quick write up on a separate post so others don't go through what I just went through.
Thanks everyone for lending a hand. Truly appreciated!
2008 E350 4Matic, 2011 E350 4matic
Glad it worked out for you and good to know that the Cardone reman is a good one. My only question would be the quality of the boots, they might use cheaper quality ones so they may rip earlier. So keep an eye on it and of course if it rips, get the MB boot kits.
21 - 24 of 24 Posts
