2003 Volvo V70 5 Speed
Hey folks, winter is here and it's more than time to get my heater up to snuff. My heat was only working when I was driving and not at idle which led to my diagnosis of a failed heater pump. With my new one on the way I remembered reading somewhere on here about a recommendation to splice in a fuse to the pumps hot line. Is this necessary? if so what size should I splice in?
-thanks, Dude99
1979 280CE
The in-line fuse modification is not necessary on cars equipped with a ACC servo(ACCII). That was for ACCIII, which had the series of horizontal push buttons.
ahh, excellent, one less this to do. So then does the Servo control the heater pump?
1979 280CE
Somewhere under the dash is a temp sensor for the aux water pump, however im sure it is all wired through the actually servo unit itself.
