1 - 12 of 12 Posts
1995 Mercedes Benz E320
The top of my center arm rest on my 95 E320 is very warn. The dealership said it would cost $1200 to replace. Isn't that the most ridiculous thing you have ever heard. Does anyone else have the same problem and if so how did you fix yours?
Black on Black S124 Estate and White A124 Cabriolet
My 95 black interior Cab needed one, found it on ebay for under $200, used, but totally acceptable. :)
BTW, I set an ebay / advanced search so I got emailed when it came up for sale. It took 7 weeks or so.
99-C43, 05-G55K, 71-280SL, 94-E320 CAB
Thank you for the quick replys. The problem is that the 94-95 W124's have two piece armrests like this
so cover in the link would not allow the armrest to open.
W124 Moderator
You might try a few of your local upholstry shops. They would certainly have the know how and materials to replace the armrest cover. Maybe try one that does custom cars or hot rods..
Good Luck,
Jayare
Two piece..DUH !!!
I should have known that...
Again if structurally sound and not ripped or torn then you can use a leather dye to freshen it up...
I use a brand called "Leather Magic" as they have the standard MB colors available.
I've done complete interiors years ago in old Jags and Aston Martins with "Leathertique"...you oil to soften, sand, fill cracks and dye...very common in the UK restoring Connoly hides......
I purchased a later model roll top and installed in my 1988 300CE...
Piece I bought was Cream Beige and I have Palomino...
Results below....
Jayare, thank you I don't know why I didn't think of that. I will go to a local shop and see what they can do and if they can't help me, then I will use the leather magic that RBYCC suggested.
Thanks for the tips.
Bro I dont Think you did your research, That same guy sells the one you need if you look in his store.
Good Luck.:thumbsup: You should also post before & after Pics:D
Cover For YOUR armrest
Thank you. This is EXACTLY what I need. I will post pictures.
Also DJ, that is a great idea except to my knowledge, there are really no junkyards with a good selection of mercedes in the metro detroit area, but I will keep looking.
1 - 12 of 12 Posts
