01 E320 w/120k
hey guys,
my alt is shot, i see autozone has these 2 for the 300sd. does it matter which one i get? both r bosch.
Reman Alternator w/Optional 65A; Internal Regulator; BOSCH; 12V; Clock-Wise Rotation
Reman Alternator w/Standard 55A; Internal Regulator
thx
12-Camel TT S600
u can get the ac delco remanufactured unit
ac-delco part number 321-1401
or Bosch Al129X from a mamber here screen named MTUPower
they both are 115AMP unit and will probably fit ur SD
1985 300sd
AL 129X will definently fit, after all, that is the model I have on my 300sd right now. And you can definently notice the upgrade.
Depends on the day!
I'm curious, what's autozone charging for these things?
Jonathan
84 300TD, 2005 CDI, 2006 CLS55
I've been busy on the new boat I'm working on and have not had time to pull more alt's. I'll be headed to NY for the summer also, so check out ebay and do a search on the al29x and you'll find a seller that remanufactures them gets about $135 for them I believe.
