Bought it this summer for my daughter's 1st car, needed a little TLC but has been quite reliable so far. Started blowing the environmental controls fuse, a fried that is a Porsche mechanic found a shorted bulb and the blower fan was messed up. He did a quick fix on the fan motor but no telling how long it will last. Is there a replacement motor from another car that might work? I have an electric place that does rebuilds of starters and alternators, maybe he can handle this also?
Thanks for any help.
Gary
Outstanding Contributor Always Remembered RI
Welcome to Benzworld Gary. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
