Just bought a 1984 300sd from a local guy with 188k on it. When i bought it i looked for common issues with smoke/ tranny/ coolant/ vacuum issues/ and electrical problems. Everything worked and it ran like a dream. ive owned the car for over a month now and the heater stopped working, doesnt even switch on when i hit the buttons, i think it may be the servo (makes a noise occasionally and sounds like a fan trying to get going). Secondly, the engines making a tapping/ popping noise on the passenger side, i hope that just means it needs the valves adjusted. theres a couple other minor issues but ill troubleshoot those later... any input about the heater and engine noise would be greatly appreciated.
Outstanding Contributor Always Remembered RI
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
