Hello all! I am the new owner and caretaker of a one owner 1986 Mercedes Benz 190 D 2.5 (5speed). This car belonged to my grandmother since new, and after she passed recently I have now acquired the vehicle. It has been garage kept since its purchase in November of 1986. The odometer reads 109,936 miles, however I noticed on the drive home that the odometer is not working, so we'll add 20-25 miles. The engine is strong, the lights all work and there are no leaks that I have found yet. I wanted to, if possible run by my plan to get the car back up and running more like a daily driver. I planned on first tackling the fluids and filters....Oil (fluid and filter), air filter, transmission (fluid and filter), rear diff, brakes, coolant. Then onto the harder jobs tackling the items that require some love.
First, the odometer needs fixed....so I'm looking at a dash removal. Second, the heater blower motor only runs on max. Even with the switch on 'I' it is still full blast from the center vents. I'm thinking possibly the resistor? This should be an easy kill with the dash removed. Third, no heat. Driving the car home I noticed no heat, granted I had the a/c off because of the fan, but in the garage at the end of the drive...no heat. Also, even with the "floor vents" selected I only get air through the center vents. Vacuum issue maybe? My Dad removed the fuse for the radio because it was only playing static (extremely loud), so replace that fuse to make sure the antenna works. The sunroof won't open....could this be related to that fuse? Lastly, I've seen good things about diesel purge....the diesel in the car is old, I'm not sure how old, but old. Would it be worth it to run some of that through the injector pump? Also, are there any additives to kill algae in diesel that are trusted by fellow MB enthusiasts? I apologize for the long first post but I am thrilled to death to have this car here. It's a piece of my childhood and my grandmother that I will cherish. Given that, I want to look after the car as best I can, and do the work myself. I'm eager to get started on this journey. Thanks for reading, and any input or information given will be much appreciated.
update I replaced the #19 fuse, and the radio, antenna, and sunroof worked. Started the car the next day and the static was back on the speakers so the fuse has come back out. Has anyone experienced this issue before? Is it best to swap the old radio for a new one?
