1 - 8 of 8 Posts
85 300SL Euro,97 SL320,95 S420,07 S550
I have a 1997 SL320 .,my transmission Control unit is full with transmission oil,is there a transmission plug to fix it or do I need a new unit.
If I need a new Unit does somebody know the price ,I can't find it nowhere.
Thank you
Discussion Starter #2
I just try again if anybody maybe has a solution
Outstanding Contributor
1997 SL600 Brilliant Silver Sport with grey/dark metal interior, 234K miles
The seal for the big round electrical connector at the front corner of your tranny needs replacing. Not too expensive.
1998 SL500, Panoramic Roof, Factory Xenons, Black/Black/Black 2012 GLK350 Black/Beige
I changed the leaking plug on my '98 500 last week. Part cost $12.00 at the local MB dealer. Takes about :30 to :45. Only tools needed are ramps to get the front of your car up, and a 7mm socket, 4" extension and a ratchet.
Search "transmission plug leak" and you'll find some very complete threads on how to do the job with lots of photos.
Thank you,how did you clean out control unit?
Fluid had not migrated into the control unit on mine. If I recall correctly, the threads I found say to use electrical contact cleaner. There is even the MB factory technical service bulletin in those threads that describes how to clean it.
Moderator
SL55, 300SE, GL450, Daytona 955i
The tranny plug needs replaced anyway, so start with that...
next, clean up the contol box, and hope for the best...
I think I remember reading that if you keep driving with the bad connector seal and the flooded control box, a new contact plate is in your future (bigger expensive trouble).
Attend to the issue pronto.
1 - 8 of 8 Posts
