Can anyone help me locate the relay for the turn signals? I shorted out my turn signals, now won't work. Changed the 4-way Emergency flasher switch, that works, but regular turn signals won't work at all. Looked all over engine bay but can't find it.<br> Changed the fuse....what else could be wrong? All bulbs burn okay when 4 way flasher is pressed...., but when putting left or right signal on, nothing works...thanks in advance.
Eric, thank you for the info. Appreciate it! Luckily it was only the fuse, couldn't tell that it had burnt out. Only after moving and turning it, then it fell apart. Replaced it and the signals work now.
