2005 B180 CDI CVT
You have to lightly tighten both bolts and with wheels (weight of the car) turn the steering fully left and right to settle the bushes. And fully tighten the bolts at normal ride height position. The bracket holds the nuts
Wishbone -to-axle carrier: 120NM + 90 degrees.
Ball joint -to- knuckle (hub): 50NM + 60 degrees.
W123 '83 200, W210 '98 E200K, W212 '13 E350
I'm a little late to the party, but one comment. I'd recommend using new hardware whenever you see a torque rating plus degrees.
2006 B 200 .....& Audi A6..
Paulo...God, I hope that I never have to do that..but if I do, I'm coming over to your place....;);)
Thanks again for everything....
