1973 416 Doka, 1978 416 Doka, 1980 416 Doka..... Help me, I can't stop buying them!!!
I need some advice on how to mount a stack exhaust on to the DoKa cab
that I am restoring for my 406. Some of you may have been following my
progress on this post.
http://www.mbnz.org/forums/forums/thread-view.asp?tid=1172064&start=1&fid=35
I am just about ready to prime and paint, so I want to know what I need to
weld onto the cab to hold the stack on. And how others have done it. I don't
want to cause more noise inside with vibrations by doing it the wrong way.
Also do you end up with soot all over the back of the truck with a stack? If
some of you could tell me how you did yours and send some photos that would
be great. My thoughts were to weld some tabs onto the driver's side back
corner of the cab, and then use rubber between the stack and the tabs. Then
use flex pipe to connect the muffler to the stack. I have a 8ft. garage door
so I don't want the stack to be any higher than that. Which puts the stack
at the same height as the cab roof. How hot does the stack get? and how far
from the cab should it be, so as to not burn the paint?
The next thing I need is the measurement between the radiator and the
inside of the grill. Since my truck is all apart I can't get this
measurement. If there is enough room I want to put my AC condenser between
the grill and the radiator. One out of a Porsche 911 will fit the whole
lenght of the front grill, so if there is enough room thats what I plan on
using. I am not putting the hydro set-up back in the truck so I should have
room under the hood for all the AC stuff.
Thanks for all the help! Von
