141 - 142 of 142 Posts
Oh boy, not another issue 🥵 Do bad mounts make the motor shift downward to create gaps in the air system?
I had a MM changed about 3 years ago. The other ones are older
A motor mount? Singular? And you didn't replace the other?
Come on, man.
Do the MM test.
Another question. This is a changeover valve gasket. The larger circle for the pipe has a raised ridge on one side. On the other side the ridge is depressed. Which side should face up and which one down? View attachment 2656818
They go either way.
1999 E320 base 180K
Discussion Starter #142
The one I changed was discovered in a safety inspection.. The other one wasn't defective at the time, it was expensive and the mechanic didn't insist on changing both. How is I supposed to know, yada yada yada. I'll look into it
