Mercedes B180CDI 2007
I bought a B180 cdi 2007 and i got 2 fault when i read the ecu, U0416 - Network and P2251 - Powertrain O2 sensor Negative current control circuit Open bank1 sensor1.
The problems i get is that ESP gets deactivated and at the same time tire air measurment is deactivated :/
and some times the engline light come up i think is because the U0416.
Need help!! which parts are defect??
W245 Moderator
2009 C300 4MATIC
U0416 - Network - check all fuses and relays, it may be also a broken ESP sensor cable (eg. front axle speed sensor or rear wheels speed sensor). ESP and air pressure go hand in hand...
P2251 - Powertrain O2 sensor Negative current control circuit Open bank1 sensor1 - have the oxygen sensor on the exhaust manifold checked, may be just wiring...
If the car has the right tire size installed, I guess it caught something under that dinged the sensor and the O2 sensor... Lift up the car, check and let us know, luckily is just the wiring...
thanx for the fast feedback!
noticed now that i have to wide tires on it :( in the manual it says 215/45 18" i have 225/45 18" in the front and 235/40 18" in the back can this be why the esp turns off??
see signature
Could be, they are mismatched circumference.
W245 Moderator
2009 C300 4MATIC
It's a possibility...
