'06 CLS500 '01 CLK320, '84 300D
Hey all...
I am in the middle of doing the rotors, and I am at the point where the rotor has to be unbolted from the hub. There are I believe 5 "hex" bolts that need to be removed. Anyone know the size of this bolt so I can buy the proper ratchet piece???
Thanks in advance
G
Guest
When you go to unscrew them what I do is mount the hub/rotor on to the tire you took off, with a couple of lugs.
