1980 300sd, 1998 e320
My charginf system is not working, and I was wondering if anyone has any info on how they work, i.e. diagram or ideas on what is usually the problem. if it is the generator, then I need to track down a used one.
thanks
The regulator,that is the big box on the firewall should be OK but the generator will proberbly need new brushes,I would look for an auto electrical out fit that has a long reputation,IE someone that has been in Buisiness for at least 30 years.They will have the expertise to overhaul your generator and should be able to do the job in a few hours.
Generators are simple technology,but todays "technicians" wouldn't know a generator from a hole in the ground.......[;)]
