Thank you guys for swift responses, I am trying to weight out the options here, I found this link would something like this possibly work to get the sound going without re wiring......[/URL]
1stop,
No FO connection on your Android HU so you are SOL.
You will have to do some rewiring. The bose system in the W163s uses the FO system and it's proprietary (as already stated). You're replacing it with a modern double din with all the bells and whistles and simply plugging it into the existing oem harness (that you show) will not work. That oem harness you connected to works in conjunction with the oem FO.
IF it were an non-FO system, it's just a plug and play.
This being said, the simplest way (which will require some re-wiring, no out-of-the-box plug and play) is to cut the wiring harness on the DS that connects to the bose amp on that side and follow the post#4 link and add your own matching harness,
OR re-purpose the oem amp box (which I did) using only the connector built into the amp on the DS. I gutted the amp and wired up the double din wiring harness to the appropriate terminals on the gutted amp. I did this for ease of connectivity to the existing oem harness.
Follow the link in post #4 on the wiring scheme and it will work fine.
FYI- the most difficult aspect of this swap was getting access to the amp under the dash (at least for us older folks)
Rewiring and gutting was the easy stuff (with the right tools)
NO additional amp replacement required unless you want to add one.
A few of us (hard-of-hearing) members dont need to drive a boom-box w163. We hear our selected tunes fine 😃
