Sorry about that. I thought as I was posting in the W124 section I wouldn't need to go into that much detail. As I'm new to this forum, I now know better. Thanks for pointing it out.battlecat714 said:car model and year would REALLY help.
Thanks for the input. I did try the fuses. I should have mentioned that the switch was/is working intermittently.Doortex said:might ot so be the switch try changing the fuse to the windows first cause in my benz the switch work and the they don't its really werid they work at random im getting tired of it too and might by new switches but a friend told me it the fuses at first it worked but then they stoped working agian but at the time only the 2 back window switches don't work
No problem. I see you're getting help already, good. Oh and Welcomepaulgold said:Sorry about that. I thought as I was posting in the W124 section I wouldn't need to go into that much detail. As I'm new to this forum, I now know better. Thanks for pointing it out.
It's a 1986 300E W124
Thanks again,
Paul![]()
hey anytime just glad to helpThanks for the input. I did try the fuses. I should have mentioned that the switch was/is working intermittently.
Thanks,
Paul
Hello,paulgold said:Thanks for the input. I did try the fuses. I should have mentioned that the switch was/is working intermittently.
Thanks,
Paul![]()
Hey,macdrone said:Pull the screw out at the end under the carpet oiece in the tray and lift up. The switches are the only thing that hold it down. That should give you enough room for access to the switch. If not then remove the ash tray, take out the two screws and pull out the whole assembly then you can completely remove the center piece.
Hi Ray,rayhennig said:Hello,
I had much trouble with window switches (intermittent working) on my 124 but that's all sorted (so far!) now. The solution? ...
Remove the switches and carefully prise the tops off. Buy a good quality contact cleaner/lubricant (ElectroLube?) from an electronics shop. Spray the contacts a few times and, if you can, clean off any more difficult deposits.
Spray again, reassemble and, with luck, you're in for a few years' operation.
On all my MBs since 1977 I have only once changed window switches and that's because my son and his friend decided to look out of the sun roof destroyed one by standing on it.
Bonne chance.
RayH
Hi Jorge,battlecat714 said:No problem. I see you're getting help already, good. Oh and Welcome!
paulgold said:Hey,
Thanks for the reply and info. I really appreciate it. Yesterday after posting my initial inquiry, I cracked the windows (except the drivers) to allow air circulation in the car while I was at work. And lo and behold now the passenger window is stuck open.
Fortunately when I bought new replacement switches I bought a pair!
Now thanks to the kindness of you guys in this forum, I can attempt to fix them.
Very grateful. Thanks!
Paul
BTW the car is a real doll. 1 owner 84,700 miles. Will post pictures when I figure out where to do it!![]()
