E3204matic
Hi I have a 1998 E320. And the driver side fog light is cracked and needs to be replaced.
Wanted to know how to do it my self. And what is the best way?
Thanks for your time.
SLK320, MKV Jetta TDI, Mini Cooper S, Lincoln Mark LT
Find the flap under the bumper below the foglight. Rotate the tabs on the corners of the flap to open it. Open the flap to get at the back of the light just like you are changing the bulb. Unplug the power wire for the light. Find the nuts that hold the fog light to the bumper frame. Fog light assembly comes out from behind the bumper frame through the hole opened by the flap. The outer lense is clipped on. Remove and replace the lense. Put the light back behind the bumper and plug it back in. Close the flap and turn the tabs back to hold it closed. It takes like 10 to 20 minutes to do the job.
