E-320
On my 99 E-320 the rear seat belt is stuck in it's fully retracted position and it wouldn't release.
I tried to remove the lower seat and unbolt the bolt that holds the seat and the other end of the belt (near the fuse) so as to let it rewind further in the hope that it would be released but it winded further and is stil stuck and doesn't release at all.
Can anyone help please.
Thanks much.
you would need a new one unfortunately.
W203, W210 Moderator
E55 ///AMG
How much would it cost to get a new one - what part would need to be replaced ??
Heres the part numbers for your rear seatbelt*
*Order by application; provide your VIN # when you order just to make sure.
BELT, OUTER SEAT:
R 210 860 58 85 - $146.00
L 210 860 57 85 - $165.00
BELT, CENTER SEAT:
210 860 31 85 - $173.00
E-320
Thanks so much for the response and the parts information.
Is there a DIY for this somewhere ? Is it easy is it to replace oneself.
So the part you mentioned is the belt as well as tensioner/release mechanism- right.
