I drive C230 kompressor of 2004 model,but each time i tune the radio on it ask for code to unlock it.have been searching for past 3 months before i goy this site.and am proid to be a member.please can any body help me out
I drive C230 kompressor of 2004 model,but each time i tune the radio on it ask for code to unlock it.have been searching for past 3 months before i got this site.and am proud to be a member. Please can any body help me out.
The radio is not keeping memory. Either the power supply to that particular circuit inside the radio has lost power, or there is no power at the plug that plugs into the radio.
Do you need the radio wiring diagram?
Yes you cam givr me the wiring diagram,but i learnt that there is a way they get the code with the vin number can you do thay too pal.
Yes you cam give me the wiring diagram,but i learned that there is a way to get the code with the vin number can you do thay too pal.
I mis-understood. I thought you had the code already, yes the dealer will give it too you.
