1 - 16 of 16 Posts
W140 S600 300D300SD
hello guys need help, my s600 had been bouncing a lot on small un-even lumps on the roads, so i just had my rear hydraulic shocks replaced, but to my disappointment it made the car even more bouncier, some say that i have to replace the air cells, what are these for? how many are there in a w140? are they expensive? can they be replaced DIY? need info thanks in advance
Banned
1996 S600 1991 560SEL 1995 S500 2009 S550
Hi, visit my shop and I'll help you on that problem, its a walk on the park to fix it, those are called accumulator, sometimes you can try bleeding the air out first, and if it does not work, then you'll have to replace both left and right side. Text me ASAP, i am leaving for germany very soon.
92 500SEL to 01 E320T current 2014 lexus LS460
Hydraulic struts for a 600 are approximately $500 ea, accumulators are $90 each, as my MB service rep says" shocks dont usually go bad, unless they leak, accumulators go at 60/80 K miles. Your mechanic should have tried those first, and yes you can change them yourself but be prepared for an oily situation. Tough to do on your back.
W140 S600 300D300SD
i havent got the time to fix replace the accumulators, is it safe to drive the car? or will some other car parts be damaged if i continue to use the car?, i only use the car once a week, on sundays when there's no heavy traffic, thank u all for the replies,
hey cool il try to visit ur shop if i can be free, im not yet done w/ my other cars.
casual driving shoud not be too hard on them, but you can do damage if you drive too long, I put up with a bouncey ride quite a while, the accumulators fixed it $350
1996 S600 (Sebastian), 1999 SLK230 Kompressor (Tie Fighter)
i did my accumulators at about 85K. i believe they are the spheres in the rear which are half filled with hydraulic fluid, then there's a wall and the other half is filled with hydrogen gas. i was told that usually the wall between the two substances gets undermined and they mingle, rendering the sphere useless. i drove it for a week or so bouncing around feeling like an idiot...hahaha. [8D]
1995 S600 (sold)
Check out this link...
http://www.benzworld.org/forums/forums/thread-view.asp?tid=1183427&posts=7&hl=accumulator+insides
Here's a very small cross section of an accumulator. I tried to make it smaller and more difficult to read, but no luck.
uhhh yea...nitrogen, hydrogen....GAS! lmfao [8D]
W140 S600 300D300SD
Discussion Starter #14
nice posts man thanks for the pics, il have my accumulators replaced next week, it costs $15 each side, plus hydraulic fluid $10 per 1ltr bottle, by the way how many liters of fluid is needed?
1 - 16 of 16 Posts
