1 - 12 of 12 Posts
here is the vin# WDBGA76E6PA135817‏
Thank you
Lap
I hate to dissapoint you, but i need more specified information, because look how i am stuck to find it in the followings
Model designation: 140076 Major assembly type: F
Group Subgroup Part number Designation Description Valid Optional with Replaced by Steering
24 005 Q000000000001 . NO PARTS INVOLVED
24 015 A1402400217 ENGINE MOUNTING FRONT RIGHT
24 015 A1402401517 ENGINE MOUNTING FRONT LEFT
24 015 A1402410034 SCREENING PLATE FRONT
24 015 N000933010193 SCREW ENGINE FRONT MOUNTING TO ENGINE SUPPORT
24 015 N000137010201 SPRING WASHER ENGINE FRONT MOUNTING TO ENGINE SUPPORT
24 015 A1409901201 SCREW ENGINE FRONT MOUNTING TO FRAME
24 015 A1402420701 ENGINE SUPPORT
24 015 A1402420801 ENGINE SUPPORT
24 015 A1402420432 REINFORCEMENT ENGINE SUPPORT TO FRAME
24 015 A1402400818 RUBBER MOUNTING
24 015 A1402401318 RUBBER MOUNTING R
24 015 A2202400218 ENGINE MOUNTING
24 015 A2202400218 RUBBER MOUNTING W
24 015 A2202400518 RUBBER MOUNTING W
24 015 A1402401040 BRACKET
24 015 A1402421340 BRACKET
24 015 A1409900112 SCREW STIFFENING TO CONSOLE
24 015 N914126008072 SCREW BRACKET TO TRANSMISSION COVER
24 015 N910105008016 SCREW BRACKET TO TRANSMISSION COVER
24 015 N000931010233 SCREW BRACKET TO ENGINE MOUNTING
24 015 N910105010018 SCREW BRACKET TO ENGINE MOUNTING
24 015 N000125010518 WASHER R
24 015 N000125010532 WASHER BRACKET TO ENGINE MOUNTING
24 015 A1249900401 SCREW ENGINE MOUNTING TO ENGINE SUPPORT
24 015 N914126008054 SCREW R
24 015 N910105008026 SCREW ENGINE MOUNTING TO ENGINE SUPPORT
24 015 A1409900112 SCREW ENGINE SUPPORT TO FRAME
24 015 N910105008016 SCREW BRACKET TO TRANSMISSION COVER Left
24 015 N000000000276 SCREW ENGINE MOUNTING TO ENGINE SUPPORT
26 075 A1402670137 BEARING BRACKET R
26 075 A1402670437 BEARING BRACKET Left
26 075 A1402670337 BEARING BRACKET R Right
26 075 A1402670537 BEARING BRACKET Right
26 075 A1292670040 BRACKET
26 075 A1402600138 SHAFT
26 075 A1402600138 SHAFT Left
26 075 A2102600038 SHAFT
26 075 A1405460217 LIGHT GUIDE
26 075 A1402600238 SHAFT Right
26 075 A2102600038 SHAFT Left
26 075 A1402600060 SUPPORT LIGHT GUIDE
26 075 A1402670074 PIN
26 075 A2102600138 SHAFT Right
26 075 N006799005002 LOCK PLATE
26 075 A1402600060 SUPPORT LIGHT GUIDE Left
26 075 A1402600253 YOKE
26 075 A1402600160 SUPPORT LIGHT GUIDE Right
26 075 A1402670501 SHIFT LEVER
26 075 A1409930120 SPRING YOKE TO SHIFTING SHAFT
26 075 A1299930020 SPRING YOKE TO SHIFTING SHAFT
26 075 A1402600253 YOKE Left
26 075 A1402670174 PIN YOKE TO SHIFTING SHAFT
26 075 A1402600153 YOKE Right
26 075 A1152670174 PIN YOKE TO SHIFTING SHAFT
26 075 A1402670501 SHIFT LEVER Left
26 075 N006799005002 LOCK PLATE YOKE TO SHIFTING SHAFT
26 075 A1402670601 SHIFT LEVER Right
26 075 A1402670050 BUSHING YOKE TO SHIFTING SHAFT
26 075 A1152670950 BUSHING YOKE TO SHIFTING SHAFT
26 075 A1402671276 WASHER
26 075 A1405450214 SWITCH 1ST SPEED
26 075 A1402670046 SHIFTING SEGMENT 1ST SPEED
26 075 A1402600262 BRACKET
26 075 A1402671040 BRACKET
26 075 A1402671076 WASHER
26 075 A1409900904 SCREW BRACKET TO BEARING BRACKET
26 075 A1295450111 SWITCH ECONOMY DRIVE PROGRAM Left
26 075 A1402670630 LEVER (LOCK-OUT LEVER),STEERING LOCK
26 075 A1402670046 SHIFTING SEGMENT 1ST SPEED Left
26 075 A1295450211 SWITCH ECONOMY DRIVE PROGRAM Right
26 075 A1402600637 LEVER (LOCK-OUT LEVER),BRAKE
26 075 N006799007007 LOCK PLATE
26 075 A1402670776 WASHER (CAM PLATE) W
26 075 A1402670246 SHIFTING SEGMENT 1ST SPEED Right
26 075 A1402670876 WASHER (CAM PLATE) W
26 075 A1249945241 LOCK (CAM PLATE)
26 075 A1402670293 SPRING
26 075 N913017006000 NUT R
26 075 N910112006001 NUT R
26 075 N913023006001 NUT
26 075 A1405401149 INDICATOR SLOTTED GATE LIGHTING
26 075 A1402600032 GUIDE SHUTTER
26 075 A1402600132 GUIDE SHUTTER
26 075 A1402670226 SHUTTER
26 075 A1406806939 SLOTTED GATE
26 075 A1405401149 INDICATOR SLOTTED GATE LIGHTING Left
26 075 B66818150 GEAR SELECTOR LEVER R
26 075 A1402600440 HANDLE GEAR SELECTOR LEVER WITH KNOTTED WALNUT FINISH,BLACK
26 075 B66818151 GEAR SELECTOR LEVER GEAR SELECTOR LEVER WITH KNOTTED WALNUT FINISH,BLUE
26 075 B66818152 GEAR SELECTOR LEVER GEAR SELECTOR LEVER WITH KNOTTED WALNUT FINISH,BRESIL
26 075 A1406806939 SLOTTED GATE Left
26 075 A1405402149 INDICATOR SLOTTED GATE LIGHTING Left
26 075 B66818153 GEAR SELECTOR LEVER GEAR SELECTOR LEVER WITH KNOTTED WALNUT FINISH,DARK-BROWN
26 075 A1405402249 INDICATOR SLOTTED GATE LIGHTING Right
26 075 B66818158 GEAR SELECTOR LEVER GEAR SELECTOR LEVER WITH KNOTTED WALNUT FINISH,DARK STONE
26 075 A2015450042 FOLLOWER
26 075 B66818154 GEAR SELECTOR LEVER GEAR SELECTOR LEVER WITH KNOTTED WALNUT FINISH,GREEN 402
26 075 B66818155 GEAR SELECTOR LEVER GEAR SELECTOR LEVER WITH KNOTTED WALNUT FINISH,MEDIUM RED
26 075 A1405450037 BUTTON
26 075 B66818156 GEAR SELECTOR LEVER GEAR SELECTOR LEVER WITH KNOTTED WALNUT FINISH,GREY
26 075 A1406807039 SLOTTED GATE Right
26 075 B66818081 SELECTOR LEVER HANDLE WOODEN SLECTOR LEVER HANDLE WITH LEATHER COVER,BLACK
26 075 B66818086 SELECTOR LEVER HANDLE WOODEN SELECTOR LEVER HANDLE WITH LEATHER COVER,MEDIUM RED
26 075 B66818083 SELECTOR LEVER HANDLE WOODEN SELECTOR LEVER HANDLE WITH LEATHER COVER, SAFFRON
26 075 B66818082 SELECTOR LEVER HANDLE WOODEN SELECTOR LEVER HANDLE WITH LEATHER COVER,BLUE
26 075 B66818088 SELECTOR LEVER HANDLE WOODEN SELECTOR LEVER HANDLE WITH LEATHER COVER, GREY
26 075 B66818089 SELECTOR LEVER HANDLE WOODEN SELECTOR LEVER HANDLE WITH LEATHER COVER, MUSHROOM 402
26 075 A1292670910 HANDLE 412
26 075 B66818098 BADGE BADGE FOR SELECTOR LEVER HANDLE
26 075 A2012670380 GASKET
26 075 N914130006501 SCREW BEARING BRACKET TO TUNNEL
26 075 A1405840838 GUMMED LABEL IN ENGLISH
There is more even..thats only 4%,
Trust me i want to help as much as possible :eek:
That the thing,the code said 26 which is upshift delay switchover valve open or close circuit.i don't know what it look like or where it located in the engine bay ,before i can check the vaccum line or replace the part.Thanks again
lap
Ok I have it located on the left side of the engine bay just behind the suspension fluid resevoir.. at about three oclock at the end of the fuel cooler...... it is a square unit with two vac leads coming out of it one at the top and one on the face nearest you...... dont have any colours for you .. but that is where it is..BUT.. find out why you have the codes what reader are you useing..and did you have any other codes..
when i got off work yesterday,the check engine light come on.my car came with diagnose mode clicker,when i ran it,#26 came up.the car run and shift fine this morning.i want to fix it before anything else go wrong.
Moderator
This is an electrical on off valve, dont worry about the tranny itself.
if its broken/stuck, it can either be stuck open or closed
if stuck open, the delay shift mode will be engaged all the time, and the car will drive like a bus, as it wont shift 2nd to 3rd until 3000rpm under partial throttle.
if its stuck closed, the car will never engage the cold start mode, it wont hurt the car itself, but the engine will take few seconds longer to heat up the cat converters us to temp.
dont worry, either way, it will not break anything... just replace the valve itself and you should be all set... as Eddie, and he will send you one for probably less than 50 bucks.
1 - 12 of 12 Posts
About this Discussion
5 Participants
orientalexpress
Mercedes-Benz Forum
Full Forum Listing
