1 - 10 of 10 Posts
G
So, I decided to go with AMG exhaust for my CLK 430. Is it ok to remove the resonator ? I want the exhaust to be a little bit louder, because from what I heard that AMG exhaust is not much diffrent than Stock. Will it pass smog check ?<br>
TIA<p>c1130646-a.wntck1.sfba.home.com
G
Discussion Starter · #2 ·
It will still pass smog if you had the resonator or not. As long as you don't mess with the cat and
forward. Did you order the exhaust from Autoclass already? <p>
G
Discussion Starter · #6 ·
Not that I know of. It will definitely change the sound though....also
if you took the resonator out, you'd need a pipe where it used to be to connect the exhaust all together -- that's just a matter of physical connections, no real issues there.<p>user-33qtno5.dialup.mindspring.com
G
Discussion Starter · #8 ·
Any muffler shop.. Get stainless steel (light. lets out heat). Just get twin pipes (if 430/55) to
the muffler<p>ca-brea5b-177.stmnca.adelphia.net
G
Discussion Starter · #9 ·
Why two pipes I put only 1 pipe in place of the resonator for a clk430, did I do something wrong???
1 - 10 of 10 Posts
