09 E350 sport
Just got into a 2006 E3504matic. Ihad a 2006 CLK350 with Brabus Reps which I took off before I turned the CLK in.The rims are 19's -8.5 front and 9.5 in the rear.
The tires are 235/35zr19's and 275/30zr19's respectively. with these tires the height ,front and back is 25.5 so these should be O.K.,right even with the 4matic?
I only intend to use this set up in the summer and switch back to the oem's in the winter.
I could use some help on this.
Thanks in advance for advice.
BenzWorld Tire & Wheel God
the bigger problem to conside is the fact that you new E-Class utilizes 14mm lug hardware (which means 14mm radius ball seats) and the old car used 12mm hardware ....
