1 - 1 of 1 Posts
Allright, lemme spit out my problem on my 1999 CLK 320 *sigh* I have been using 19" 245 width Carlsson evo 1/6 for a while, cut the H&R springs and had it lowered so bad (but I took those out and have them replaced with cup kits now). Recently, I just found out that the front right HUB of my car is screwed up. Apparently, one of the lug holes is corroded due to the rims. The center caps of the wheels are not fitted nicely to the HUB and it caused the lugs to hold the wheels the entire times. The Mercedes technician gave me two options. First, change the HUB which would cost me around $2,000 and the other, buy wheel spacers and longer bolts for the whole HUBs. However, he still recommends me to change the front right HUB. Are there any reliable repair shops in LA that can help me? Please advice me about this issue. Thank you.
1 - 1 of 1 Posts
