We have a 85 500 SE that we just purchased on ebay..the car had been sitting for about 3 years..We got it home and I tried to put a little anti-freeze in it...crack right behind the starter...
Has anyone seen or heard about this...I dont think it was from freezing..we are in the south and I dont think it had water in it..
Can it be welded? or engine replacement needed..
Thanks for any help....
2004 ML270
Any more detail on where the crack is?
If it's a cylinder wall it can be sleeved and if it's a non structural area it can certainly be welded.
What's the rest of the motor like? Might end up being cheaper doing a motor swap.
Post a pic.
Matt.
1982 300SD
Just to ask the obvious question...
Are you sure its a crack? Can you see it? The reason I ask is that you state its behind the starter. Is it possible that its only a block plug that is leaking?
Also there are some epoxies that some have used to repair some cracks. Sorry about all the "some" in that last sentence, but I want to be sure to convey that this is an iffy repair--that works, sometimes.
