Need help changing amber sidemarker to clear, pls!!!
1051 Views 1 Reply 2 Participants Last post by  Drew
just as the topic says, i need help!
i read the manual for changing bulbs but when i try to "carefully" push the sidemarker to the rear it doesn't seem to budge (i am also scared i might push it back too hard and break it). any info will be greatly appreciated. thanx![:)]
It's tight...
You might want to wrap a slotted screwdriver's edge with masking tape and then use that to help you to pry the front part (furthest from the wheel, to give you some point of reference) of the lens out a bit. You will need to pry outwards and push backwards simultaneously so that the lens clears the plastic lip that holds it in.
Are you changing the lens to a clear lens, as I did?
Good luck!
