04 S430 4matic
Hi, i have a 2004 S430 4m and tonight i was driving it and stopped at a red light and the car just turned off. It was cranking but not starting. After about 30 min, tried again and it started. Drove it for about 5-10 min to the dealership and it turned off again and could start it anymore. If you know what can possibly be wrong, I'd greatly appreciate any info. Thanks in advance :thumbsup:
W221 & Audio Moderator
2013 S550
This problem is described in the W220 S-Class Encyclopedia sticky at the top of the forum.
10 Mercedes e350, 09 Mercedes GL450, 95 BMW 325IC, 89 Mercedes 260E, 84 Euro Mercedes 300D 4spd
It is defiantly a crank position sensor,
I had the same problem few years ago
1997 E420 & E320
before you start replacing sensors check with a diagnostics system for codes. More than likely It is the sensor mentioned above.
good luck.
