Need Help: 560sl Vacuum valve diagram or picture
13K views 3 replies 2 participants last post by  Hillingdoner
Hi,
1986 560SL I was working on the Idle Control Valve and accidentally disconnected the hose to the Vacuum Control Valve. I dont have a diagram on my car. I can't find where the yellow hose connects. Doing a search, I see another user had similar request but not answered.
Where does the yellow hose connect?
Thanks in advance.
Hopefully this helps.
Here is the section I found in the online service manual that has diagrams.
https://www.startekinfo.com/StarTek/outside/11883/PROGRAM/Engine/107/M117_56/14-050.pdf
Also a lot of vacuum diagram info and schematics in this post:
http://www.benzworld.org/forums/r-c107-sl-slc-class/1453268-107-vacuum-diagrams.html
You just need to dig through to find your applicable chart as they are not in order.
I don't have a 560, but my first guess for that line would be to look for a thermal vacuum valve burried under stuff on the intake area. Valves usually have a single straight up connection off the top and another that comes off at an angle. They open and close by temp. Just a guess looking at it. As I said, don't have a 560 so no direct experience.
Hope the diagrams help!
