2005 E320 CDI 120k
I am in the midst of replacing my compressor and condenser. Both were diagnosed bad by my indie mechanic. I can see the condenser leak now that it's out and the compressor clutch had failed throwing a code.
My question is with new compressor and condenser, should I check and/or replace the expansion value and/or flush the evaporator? I have the MB PDF instructions on how to get to the expansion valve (how to remove water drain, left/right vents, wiper), but really would like to know how important it is and how much effort this job requires in order to get to the expansion valve ?
There are many cases where a shop would not necessarily replace the expansion valve and/or not do a evap flush - outside of a MB dealer only select top tier MB indies would go to that extent - and general auto aircon shops mostly wouldn't go that miole either.
The expansion valve from Egelhof is affordable - but a bit of a pain to get the expansion valve off and back on - the non-Egelhpf's frankly aren't that great.
It's up to you - on compressor the Sanden Behr is quite a value as a brand new affordable OE-Denso-compressor around $265 techchoiceparts.com
Keep the beat !
2005 E320 CDI 120k
Thank you for your opinion! This is kinda what I was figuring. The indie didn't tell me he was going to go to all that trouble.
I have the techchoiceparts.com compressor and a Behr condenser from eBay.
If it was me I find a MB indie or a good general auto air con shop to do the work at a reasonable price with the parts you have in hand.
For the right shop compressors and condensors jobs get done all the time - and they are effective with their actual shop times.
Keep the beat !
2007 E320 Bluetec, 2008 320ML CDI
While the expansion valve is optional, I thought the receiver/dryer should be replaced if replacing the compressor and condenser. Will need new hose from dryer to condenser too if you go that route.
Skippy
Sent from phone.
1999 E300DT (RIP) 2001 E55
This is a tough call.
I replaced only the clutch on my compressor years ago and it was a BITCH. I was lucky in that it was only the clutch was bad and the compressor hadn't "shelled out" or experienced "black death" which would've mandated a flush.
Several years later it happened again and I had an Indie replace the compressor/receiver-dryer and flush the system to the tune of many $$$. No problems with the E300 since. They DID happen to replace the expansion valve though.
I have since tooled up for A/C work with proper gauges and a 2 stage vacuum pump and would personally perform a compressor replacement in lieu of a clutch repair the next time around. If I suspected system contamination, I would remove the compressor,receiver-dryer, expansion valve and have a shop just flush it out with me performing all the other work.
From personal DIY experience, I had just a condenser leak on my M3 which I fixed with a new condenser and receiver-dryer w/o replacing the expansion valve and have had no problems with it.
Found a DIY for a W210 expansion valve replacement here that doesn't seem bad:http://www.benzworld.org/forums/w210-e-class/1531641-removing-c-expansion-valve-w210.html
