I purchased an A 203 827 53 42 command US version for my 2004 CLK 500. I got the system installed and everything works ok except...I can not get the unit to communicate with my steering wheel.
I had a local guy connect to the OBDII and let the unit know that I have command and that the unit is a A 209 not a A 203. He got the "fault" communicating with the steering wheel. The navigation does work as well as the auxillary system that I installed.
The C2 connections are as follows:
Pin 9 - Brown/Red wire
Pin 8 - Brown wire
Does any one have any thoughts as to why it is not communicating?
W203 modified
mjm4414 - 4/18/2005 4:39 AM
Pin 8 - Brown wire
Is wakeup (blue) plugged into C2 pin 10 ? otherwise it will just sit there and do nothing.
Yes - I think you are referring to the D2B wakeup wire. It is in pin 10. The CD and stereo works fine.
W203 modified
mjm4414 - 4/19/2005 10:24 PM
Then you need to start all over again and check to see if the crimping is up to standard.
How certain are you that the headunit is up to the task - as in working 100%.
