dose anyone have info on the possibility of upgrading to a command with nav on the 2003 E class. The dealer says not possible![?]
What else is new?
Here are some links with info:
http://www.mbenznl.com/products/w211comands.shtml
http://www.mbenznl.com/products/dvdnav.shtml
Here is a link with pics on a W211 comand retrofit:
http://groups.msn.com/MBenzNL/installdetails.msnw?Page=12
In short: it can be done, both comand head unit and nav.drive can be retrofitted in your W211.
greetingz,
BigSis
W203 modified
1donnell - 3/17/2005 7:57 AM
If you have the premium sound system then its actually quite reasonable.
If you have parktronic and the phone system then its also not so bad because the trunk will have brackets and appropriate trims in place.
If you have a car with no options and want navigation then its going to be more expensive than a car with parktronic and existing Harmon Kardon.
