2003 ML350
Is there a way to change the radio station when using the navagation function? I will have my radio on and using my navagation, but when I want to change stations, I hit the radio button to change stations then I hit the nav button to display map. Its an inconvience. So just wondering if you can change stations without switching back and forth have nav on mcs while changing stations.
thank you
1982 300TD
Nope. You have to switch back and forth. Yes, it's annoying. Also annoying is the fact that you have to have the radio on if you want to use the Nav. If you don't want to listen to the radio of the tape or the CD then you have to turn the volume all the way down.
Best Regards,
e
