2000 E430 4Matic
On my 00 E430, w210 series, the battery is under the rear passenger side seat.
when I lift off the seat, there's a thin layer of foam/cushion that is covered with think plastic on both ends.
My assumption is it's there to absorb water incase water is spilled on the seat so that the electronics under the seat doesnt get soaked etc.
I need to change that because it's deteriorated. I called up the dealer parts dept. but they didnt know what the part number is or what it is called.
if someone could give me the name or the part # for it, I could then order it.
thanks in advance.
'07 GL320CDI
Study this illustration.
Note that some items are mirrored on right side but not necessarily shown again in the illustration.
Tell your dealer this is group 68
2000 E430 4Matic
thanks for the reply.
in the diagram, which part # is the mat here so I can refer to it when I call the parts dept. Not so sure if I follow your logic.
'07 GL320CDI
Posted the picture so you could identify what you need!
2000 E430 4Matic
I'm sure that mat must show up in a different diagram. it's now showing up on this one. thnx again.
